Thread: Pump for Waterfall
    Pump for Waterfall
    The pump for the pool has a clear top so I can plainly see if there is debris in the strainer. I was wondering does the pump for the waterfall also have a strainer, and does it require to be cleaned out. The cover is not clear and our old pool guy never mentioned if I had to occasionally clean it out.
    Thanks
    11K SWG Freeform IG pool w/ spa; Bluehaven 550 (hayward mfg) Cartridge Filter; Century Centurion 2HP Pump on pool; Hayward 400H heater; Polaris PB4-60 Pump on cleaner; Hayward Super II Pump on waterfall, Hayward TurboCell GLX-Cell-5; AquaLogic PS8, Taylor 2006k
    Pool Chlorinator @ 80%; Filter from 11AM-6PM, Cleaner from 11AM-2PM
    Re: Pump for Waterfall
    I would think that the pump for the waterfall comes in line AFTER the cartridge filter. By then the water should be clean enough that nothing would be in the strainer. Obviously it doesn't hurt to check but you should not have to regularly empty the waterfall pump strainer.
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    38,262
    A Super II definitely has a pump strainer basket. How dirty it gets depends on where the suction line is plumbed.
