Results 1 to 8 of 8
Thread: CYA adjustment before getting rid of algae
    Apr 2013
    Sherman, TX
    8
    Ok, about ready to turn my green swamp into a sparkling oasis, but I've got a question after reading through pool school, etc.
    Currently, my CYA is at 10, so I know I need to add stabilizer in a skimmer sock before I get this all going. But I've got some conflicting signals here. I've read a couple places on here that you can't backwash for a week after adding solid stabilizer, which would imply that I would need to add stabilizer and let it alone for a week before I even started taking on the algae. However, the "Green Swamp to Sparkling Oasis" post seems to imply that I can drop that stabilizer in the skimmer sock and get going with it right away (of course, I would be backwashing within a few days then). Which is best?
    And, if I can start killing the algae right away, should I be bringing the water to the shock level according to my CYA reading of 10 or what I hope it will be by adding the stabilizer (hopefully 40). Thanks for all your help!
    ~Tony
    12500 vinyl IG, Triton II sand filter, 1.5 HP single-speed pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,045
    Re: CYA adjustment before getting rid of algae
    Sounds like you're armed with the knowledge, so... measure out enough CYA to get you where you want to be. Pour it in an orphaned sock or nylon. That's right - nothing special. A sock sock, not some special gimmick the pool store sells. Tie it closed with a string and hang it over the edge of the pool in front of a return jet. Fill one of those empty bleach bottles with water to use as a weight and tie the string to the handle. Adjust pH, then start the shock process based on the FC you calculated using whatever value of CYA you dosed for. It won't show up on the test for about a week; just assume that if you added enough to get you to thirty, that its thirty, and raise FC accordingly. Don't bother testing anything but FC and CC during the process, and after a week, test CYA and see how you're doing.
    And we want pictures. Lots of them.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Quote Originally Posted by Richard320
    ^Ditto (especially pictures!!), if you are using "something" that dissolves the CYA granules before they enter the 'Body of the Kirk' (ie your water) (for example a sock) then you don't have an issue with backwashing, following the Pool School instructions, it's only if you add the granules partially or totally undissolved that it would settle in the bed of your sand filter and be washed down the drain if you backwashed in the first week.
    Stuart Murray
    Scotland UK
    UK NPPOC
    Apr 2013
    Sherman, TX
    8
    Ok, that makes a lot of sense. But I'm going to need to add about 3 lbs. of CYA according to the pool calculator. I'm not sure I've got a sock that big. Can I just put a portion of that in, keep an eye on it and once it's mostly dissolved, refill the sock?
    Jul 2012
    296
    Quote Originally Posted by ashearer26
    Yes you can indeed, remember to shoot for lower than your target, you don't want to go higher than your target then have to start draining to get it back down, for example if your shooting for 60ppm shoot for 40-50 to start then top it up a week later.
    Stuart Murray
    Scotland UK
    UK NPPOC
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Since you're clearing a swamp 40 cya sounds good, high enough to protect the chlorine from the sun but not so high as to make the shock level un-reasonable. Depending on how much you have to backwash, once you've cleared the pool to the oasis level check CYA again because it may have dropped some. Then dose to your desired maintenance level.
    And we want pics!
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Absolutely! In fact, when it comes to CYA I'm very cautious in my additions so that I don't accidentally overshoot my goal CYA level. Its a PITA to remove once in, but you can always easily add more later in doses.
    I use a small section of pool noodle (toy) to suspend my CYA sock on, and it floats around freely. I give it a good squish with my hand now and then and it gets dissolved in no time.
    Apr 2013
    Sherman, TX
    8
    Okay, sounds like I've got a plan. It has randomly dipped down into the low 40s in northern Texas today, but as soon as I can stand to go back outside, I'll begin to take this thing on. Thanks for all the advice! Pictures forthcoming!
