Thread: Ladder holes plugs ?
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    Anybody knows if we get plugs or covers or something similar to hide ladder holes in a concrete deck?
    We have a small non-diving pool and the ladder is useless to us (we use the stairs instead). The ladder is also "in the way" so we'd rather not have it at all. Unfortunately, when its removed, it leaves 2 unsightly holes in the deck.
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
    Mar 2007
    Morris, IL
    How about an umbrella in one of them? Or you could rig up something else, make a table to fit in there. Either that I am sure you could find something to stick in them if you know the Inner diameter you should be able to get a stainless plug or something.
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
