Thread: Robotic Cleaners - Jet or No Jet? - HELP
    I'm going to purchase a robotic pool cleaner and have somewhat narrowed my choices:
    Non-Jet Units:
    AquaBot - Junior
    Dolphin - Nautilus
    Polaris - 9100
    Smartpool - Smartkleen
    - Scrubber 60
    - Climber
    SwimBot - HD
    Jet Units
    AquaBot - Turbo T Jet
    - Thunder G Jet
    I'm looking for any feedback on these! It's quite an investment and I don't want to make the wrong purchase. I have an in-ground 20,000 saltwater, pebble-tec pool. Depths of 3 1/2' to 6 1/2'
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Re: Robotic Cleaners - Jet or No Jet? - HELP
    I use the Aquabot T Jet Turbo I like it very simple. For your pool type I mind suggest a scrubber type. The ones I see pop a lot in search results are the Dolphin, Aquabot and Smartpool. I know Aquabot and dolphin have a somewhat large support backing.
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    38,284
    I agree the Aquabot T is a nice simple design. However, I tried one and found that as it picks up dirt, the propulsion jet is directly reduced. In my case, then meant that very quickly it would end up stuck in the deep end.
    You can only set a time for when it reverses directions, it would slowly try to climb out of the deep end and then reverse and quickly end up at the bottom again, eventually it would not have enough time to climb out.
    Likely it would work pretty well on flat bottom pools or those shallow depth changes.
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    I agree when I use the fine mesh bag it will slow down after a few hours but by then it usually has done a pretty decent job, however if you use the standard mesh it doesnt have much of an issue slowing down. I had to adjust the timer and axle pivot degree a few times but compared to vacuuming and that it cost me 499.00 I cant complain. I sort of worried about the using a scrubber type robot on a vinyl pool.
