Thread: Air bubbles out of return lines
    Although I have read posts throughout the site with the same problem, none of them seem to be quite the same problem I am having. I have a 14,000 gal. indoor plaster pool. I am currently experiencing air bubbles coming out of the return lines and cannot figure out why. It all started when I was done vacuuming the pool. Now all of a sudden there is air coming out of the return lines. I am curious to know if anyone has any suggestions. This happened Friday and it is now Wednesday. I tried vacuuming again today, and I was unable to get any suction in the vacuum line. My pool uses a seperate vacuum line. Thanks in advance!
    Troy
    My Pool: 15K gal IG Diamond Brite/gunite with 7' spa, Jandy DE 48sq. ft. Filter, Aquapure SWG, TF-100 Test Kit w/ salt test.
    22,550
    Re: Air bubbles out of return lines
    Welcome to TFP.
    What most likely happened was that the increased suction head from the vacuum opened and suction side leak. Do you see bubbles in the pump basket?
    Can you post a pic of the equipment pad? That may help us give some pointers as to where to look first.
    Sep 2009
    Frederick County, MD
    184
    Strangely (at least to me) but I tend to get air bubbles when my cartridge is dirty.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Do you have an airbleed on the filter from the vacuum line?
