Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: BONDING ?
    BONDING ?
    i already have a 110volt 20 amp outdoor plug located 5-7 feey from where the pump and filter will be setting so i can just plug it. this plug is located right beside where electric service is going into my garage. there is a grounding rod in the ground with a copper wire connected to it for the garage now. what will i need to do to bond the pool if anything or do i just plug it in and go thx
    15x30x54 AG,2HP2SP PUMP 400LB SAND FILTER
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: BONDING ?
    Do you know what code is for where you live ?
    For the pool you need #8 AWG bare copper wire to go all the way around the pool 18 to 24 inches away form it and attach it to the pool at 4 locations evenly spaced apart. Then it gets buried.
    Water also needs to be bonded. It will get connected to the pool bonding then to bonding lug on pump motor.
    Jeff
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: BONDING ?
    Here's a very good vid of what I'm talking about.
    http://m.youtube.com/#/watch?v=x6KMtrIa ... 6KMtrIa2x4
    Jeff
    Re: BONDING ?
    Bonding and grounding are unrelated. There is no reason to tie the bonding system to a ground rod, though it will often end up connected indirectly.
    Re: BONDING ?
    I AM TOTALLY CONFUSED ON THIS I THOUGHT I JUST NEEDE TO PLUG IN THE PUMP AND GO SWIMMING PLEASE HELP
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: BONDING ?
    Did you watch the video ?
    Jeff
    Re: BONDING ?
    WHICH ONE DO INEED TO WATCH THERE IS ABOUT 10 O THEM
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: BONDING ?
    Above ground pool elec install
    Jeff
    Re: BONDING ?
    CANT PULL IT UP IT TAKES ME TO A BLANK PAGE
    22,548
    Re: BONDING ?
    How old is your pool?
    Who installed it?
    What is your location?
    Bonding is important. It's basically a loop of #8 awg bare solid copper wire ran all the way around the pool and tied to it in 4 places and it extends to every piece of metal and electric equipment within 5' of the water and includes the pump and any other electrical equipment that touches the water. It sounds like a lot, but on most aboveground pools it's really not.
    If you can post a pic of the pool and equip we can tell you what needs to be bonded and how to do it.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: BONDING ?
    Ok. Google above ground pool bonding.
    Sorry about the bad link.
    Jeff
    Re: BONDING ?
    THIS IS A NEW POOL INSTALLATION WILL BE PUT IN MAY 13TH. IS THIS SOMETHING THEY WILL DO WHEN THEY INSTALL IT?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: BONDING ?
    You would have to ask them. Are they doing the elec? An electrician would be able to do it.
    I did my own its not hard to do.
    Jeff
    22,548
    Re: BONDING ?
    You need to ask them that specific question. Most installers don't handle electrical and they consider that electrical.
    If they're responsible for the electrical install then you should definitely request that they do it.
    If you have to have an inspection on the install, it'll have to be done if your AHJ requires it.
    Re: BONDING ?
    THEY ARE NOT DOING ANY ELECTRIC. WILL LOWES HAVE EVERYTHING I NEED TO DO THIS
    22,548
    Re: BONDING ?
    Lowes should have everything you need.
    Re: BONDING ?
    SO FOR A 15X30 FOOT OVAL I WOULD NEED 100 FOOT OF #8 SOLID COPPER WIRE 4 GROUND LUGS FOR POOL 4 FOR LEADER WIREE TO MAIN WIRE AROUND POOL AND CONNECT ALL OF THIS TO PUMP RIGHT. FOR THE WIRE THAT GOES AROUND POOL DO I CONNECT BOTH ENDS TO PUMP OR ONE END TO PUMP AND CONNECT OTHER END TO POOL?
    22,548
    Re: BONDING ?
    You run a loop about 24" from the pool, and it needs to be connected to the pool in 4 places, and extended to the pump. Like the following drawing.
    [attachment=0:15veymiu]Pool Bonding.jpg[/attachment:15veymiu]
    The thick line is the pool wall and the thin lins are the bonding wire. This is just shown diagramatically. Your installation will change to match your actual design and layout.
    Re: BONDING ?
    THX I GOT IT KNOW SOUNDS LIKE SOMETHING PRETTY SIMPLE THAT I CAN DO MYSELF RIGHT AFTER THEY FINISH THE INSTALL BEFORE I DO A LITTLE BACKFILL AROUND THE POOL PS: LOVE THIS SITE YOU GUYS ARE AWESOME
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: BONDING ?
    You must remember the water bonder is in this loop too.
    Jeff
