Thread: what's the difference between these calcium chlorides?
    Aug 2010
    Charleston, South Carolina
    77
    I had been buying Regal Calcium Increaser but it's a little pricey at about $2 a pound.
    http://www.thewaterboys.net/shop/index. ... uct_id=132
    Then I found Buckman's Calcium Chloride Flakes which is only about .38 cents a pound
    http://www.buckmansinc.com/store/Calciu ... 4I_84.aspx
    What's the difference?
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    38,275
    Re: what's the difference between these calcium chlorides?
    Well, the Buckmans is 77+% Calcium Chloride while others I have seen are ~95% Calcium Chloride (I did not find the MSDS for Regal specifically).
    The Buckmans MSDS does not say what ~15% of it is ... likely ok, then again, who knows.
    The other 15% is essentially all water. Flake type calcium chloride comes anywhere from 77% to 87% calcium chlorine with nearly all of the remainder made up of water. The 95% stuff uses an additional processing step to remove nearly all of the water and gives you a more concentrated product. You have to use a bit more of the flake products, but otherwise they are the same as the 95+% version, and the price is often very attractive.
