Thread: Debris in line
    Debris in line
    I have a PCC 2000. When replacing a valve base some of the PVC piping fell into the valve lines. Anyway to get this out before I start everything back up??
    18,000 Gallon in ground plaster pool. Hayward SP-3010X15 pump. Tons o' stains
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Debris in line
    Welcome to tfp, markfj
    I didn't know what a pcc-2000 was...so I googled...floor cleaner. If the debris is before the floor valve, could you just remove that floor valve and turn on the flow to that valve location to blow it out?
