Results 1 to 10 of 10
Thread: 3 way Jandy valves
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    3 way Jandy valves
    I got a stripped screw !!! On my Jandy valve I think it's leaking air!
    Is there a good fix !! Other then replacing valve ??
    Thanks ....
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    ps0303's Avatar
    Jul 2011
    FL
    3,682
    Re: 3 way Jandy valves
    First confirm it is sucking in air. You can try the shaving cream trick and see if it gets sucked in when the system is running. If you do have a leak there, you can try several things such as maybe drilling the head off and then remove the top of valve and them use vise grips to remove screw. You can also try and seal the leak with some pool putty. Of course the best would probably be to replace the valve. I bit more work but at least you know it's foxed.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Seanhan
    Thanks ....
    I'm assuming you mean the threads in the plastic body are stripped? You could try going up a size on the screw. That may involve some careful drilling. Or purchase a C-clamp and squeeze it shut with that. It'll look hokey, though.
    22,541
    Is it just stripped or is the housing cracked around it?
    If it's just stripped you can use some epoxy to fill the hole and then drill it out to accept the screw again.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Its just stripped inside the thredded hole
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Bama what kind of epoxy would you reccomend ..
    And should i use a tap the same as the screw ?
    Sean Hannon
    22,541
    AB pool epoxy should work. Those screws should be self tapping so just drill the hole the size of the screw shank. Tap it if you're concerned.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Are you talking about AB brand epoxy pool putty or just epoxy with part A and part B ?
    Sean Hannon
    drill & tap up one size, epoxy last resort
    22,541
    I was talking about the A+B brand, but any brand will work. As Nova mentioned, going up one size screw will work as well.
