Thread: Through the wall skimmer - above ground Intex pool
    Apr 2013
    Greenwood, South Carolina
    5
    I want to add a through the wall skimmer to a 20 foot round Intex above ground pool. Would a wide mouth skimmer be okay for this size pool or would a standard skimmer be better? Concerned if a wide mouth skimmer is too wide of a mating flat surface for a circular pool. The standard size skimmer may be sufficient for the job.
    Can the upper horizontal cutout in the liner for the skimmer be made just below where the liner top rail overlap end is inside the pool?
    Thanks
    22' x 52" Intex Ultra Frame AGP, wide mouth skimmer, 3/4 HP Pentair Dynamo 2-speed pump, 18" dia SandMan filter, Intex SWCG
    22,553
    Re: Through the wall skimmer - above ground Intex pool
    A wide mouth skimmer will be fine on a 20' pool.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Mar 2013
    Oklahoma
    25
    @spiderman21010, I ended up getting the standard size Hayward skimmer from Amazon and it works awesome. I too was unsure if the wide-mouth variety would be too wide, so I aired on the side of caution. Here's the one I got:
    http://www.amazon.com/Hayward-SP1091LX- ... ol+skimmer
    Here's some pics of it after installation:
    http://s1332.photobucket.com/user/willi ... t=6&page=1
    Hope this helps.
