Thread: Sharing my repair info on pool pilot Dig220
    Apr 2010
    Parrish, FL
    12
    Pool Pilot was installed in 2003 and I moved into the house in 2009. I've had to do a few repairs and save money at the same time.
    When the system quit it had bad capacitors on the main board. Replaced the 2 large caps. When they are bulging they are bad. Allot cheaper than a new board.
    The age and heat wear them out. Ordered them from Digikey. That got it working again.
    Next the display was hard to read. Ordered a new replacement digital display from noritake-elec. Must be the upgraded version. About $25 plus shipping. Works great.
    Later on intermittent readings from Tri-sensor causing crazy readings. The connection at the sensor is a problem with these so what I
    did was add solder to tin the sensor terminals. The solder creates a more solid connection when the plug is installed. I know the new versions come with the cable attached to
    the Tri-sensor but I can't help but fix things. Working good again.
    If someone has problems with there system maybe this info might help.
    Mike
    11,000 gal., Cartridge filter, IG SWG, pebbletec, pentair 2hp, 150gpm, sf 1.1
    38,313
    Re: Sharing my repair info on pool pilot Dig220
    Thanks for the information!!! It very well could be handy for someone in the future.
    Apr 2010
    Parrish, FL
    12
    I've got allot of information from here so I wanted to contribute a little of my own.
