Thread: DE alternatives?
    Apr 2013
    San Diego
    21
    DE alternatives?
    I have an old DE filter with no backwash capability, so I have to spray the grids off by hand in my backyard. As you might imagine, this has made a small patch of almost-cement where the silica gets deposited. Even with a backwash system, I don't believe I can simply pump the DE into the waste water system (because it's San Diego and there are regulations for everything).
    Are any of the DE alternative products worth using? Would they form less of a hard layer when spayed off over my yard? Any experience and comparisons from users would be greatly appreciated!
    Re: DE alternatives?
    There are various products bases on wood fiber that are biodegradable and can be used as a substitute for DE. Some brand names are Fiber Clear, ZeoFiber, Purifiber, and several others.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Quote Originally Posted by TheElbow
    My lawn seems to thrive on fiberclear. I blast the clumps to spread it around and there's no crust anywhere, after three backwashes.
