Results 1 to 11 of 11
Thread: Muritc Acid
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    Muritc Acid
    Hello everyone
    I'm a new pool owner and I will have a lot of questions in the near future
    Just want to know about this one to start
    Is it safe to use muritic acid in a fiberglass pool to manage ph levels
    Thanks
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    38,251
    Re: Muritc Acid
    Welcome to TFP!!!
    Yes, muriatic acid is fine to use in any pool. Just pour it very slowly in front of a return jet in the deepest part of the pool.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Muritc Acid
    Yes, but be sure to add it properly:
    Muriatic acid should be added to the pool by pouring slowly in front of a return jet with the pump running................. Leave the pump running for at least 30 minutes after adding muriatic acid.
    Pool School is your friend.
    Welcome to the forum
    You're done SLAMing when:
    SkyKid's Avatar
    Apr 2013
    137
    Re: Muritc Acid
    are the return jets where the water comes back into the pool?
    Thanks for the warm welcome and answers
    38,251
    Re: Muritc Acid
    Quote Originally Posted by SkyKid
    Correct. They will help mix the chemical into the water so it does not sit on the bottom of the pool and cause problems.
    If you have any concerns, you can also just do a quick brushing of the bottom to ensure it is mixed into the water, but this should not be necessarily if added as we described.
    More info here:
    pool-school/recommended_pool_chemicals
    SkyKid's Avatar
    Apr 2013
    137
    Re: Muritc Acid
    One more
    is muriatic acid ok to buy from lowes
    http://www.lowes.com/pd_206474-34228...uriatic%2Bacid
    30,403
    Re: Muritc Acid
    You can buy it anywhere you like. Usually is 31.45% but there is more and more that is only 15% so check the label....31.45 will be a better deal, normally.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Muritc Acid
    One more
    This stuff is fine. If you scroll down a bit it tells you that the concentration is 31.45%.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Muritc Acid
    SkyKid, if you are new to working with muriatic acid, you should read handling info.
    You should wear eye protection and most recommend gloves. Watch out for the vapors, too.
    Stored the MA by itself, and away from chlorine sources.
    Do a google search, bottom left of each page, for something like "how to handle muriatic acid" and read a few threads. Here's one:
    best-way-to-handle-muriatic-acid-t19300.html
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Re: Muritc Acid
    Yeah you really have to be careful with the vapors. Especially if there is a wind blowing a bit towards you.
    I've had that unpleasant feeling more than once.
    You really need to handle it properly. It is strong stuff.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    SkyKid's Avatar
    Apr 2013
    137
    Re: Muritc Acid
    I have used muriatic acid before and know how nasty it can be
    Thanks for the warnings can never be too careful
