Results 1 to 8 of 8
Thread: Liquidator / I've got ports on pump, but are they the...
    ...right ones?
    Two ports on my pump... can these be used with my Liquidator or do I still need to drill into my fittings and thread them (I'd rather not use the clamp method)?
    Pete
    P.S. Sorry the text is small on the pic... Port #1 is on left, Port #2 is on right...
    16000 Gal. Kidney / Gunite / SE Florida / Taylor K2006 / Stenner
    Jandy CS100 / Sta-Rite U3 Skimmer / Pentair Great White / Single Floor Drain / Single Return / Hayward SP2300VSP
    I'm still learning and I know nothing!.. I'm loving the Stenner!
    Aug 2010
    Dallas, TX
    4,052
    Re: Liquidator / I've got ports on pump, but are they the...
    The one on the basket can be used. I don't know about the one on the side of the pump.
    Believe it or not, those clamps work just fine.
    22,551
    As Robbie said, you can use the one on the front of the basket but you'll still need a port for the inlet to the LQ on the discharge plumbing somewhere.
    Which begs to ask: What is the other port for?
    the basket port will work fine but as already said you'll need to tap a return line for inlet to the liquidator.. you may not need a check valve in the line going to the pump basket. I do not have one on my liquidator. also just an fyi-- i've been using a pinch valve from u s plastics to controll feed for the last month or so.. so far it works great at very little cost compared to a good needle valve........
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Quote Originally Posted by FixItPete
    Those plugs are to drain the system in places where it freezes in the winter.
    I've been reading that there is a drain on "both sides of the pump" -- do I take that to mean suction and discharge?
    22,551
    I think that just means physically on the sides not hydraulically.
