Thread: Solar Heaters In New England
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    All,
    Has anyone had any luck with any type of solar heater in N.E?
    I have 40k gal I/G with very good sun.
    What type of temp increases do you see?
    What is the cost of your unit?
    Thanks
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Solar Heaters In New England
    I can't help on the regional part, other than to suggest perhaps googling "pool solar Canada" for a broader sample of people from a similar or colder climate. As to price it is a function of panel coverage, type of panel, quality, DIY vs Professional Install, etc. The big thing here is to match up your selection and your expectations, adding a solar heater that will extend your swim season by a month on either end is going to be very different from adding one that will extend you to 9 or 10 months of the year. This is not just about size of the panels, but also type, typical unglazed black "plastic" panels only effectively work if the peak daytime temperature is within about 15 degrees of your desired pool temperature, beyond that and their effective BTU transfer starts dropping off considerably, and gets even worse if you add wind. Going beyond that 15 degree F window and you start getting into the realm of much more expensive glazed panels, and other technologies. As to panel cost of unglazed solar panels, I just installed a new set of 4x12 Techno Solis panels as a semi DIY project (had a couple of professional roofers do the roof top part), panels ran about $270 each including mounting hardware kit delivered, plus about $300-$350 for PVC, plumbing fittings, glue etc. I already had a solar controller ($350 and up depending on model, mine with automatic valve now sells around $500), labor was 2 half days for 2 guys, (one was mostly a helper) for the roof top part (11 panels, plus running PVC to the edge of the roof), and about the same labor time for me doing the ground level plumbing, this was replacing all my old exposed solar PVC, making things line up with the old pipes, holes was the hardest part. I would call these panels an mid range option, cheaper panels can be found for under $200 each, and I had price quotes that went as high as about $450 each for somewhat better panels.
    Ike
    p.s. also add about 4 hours of prep time, laying out the panels on the ground, painting the PVC going on the roof, and of course a LOT of hours spent online doing research, reading installation manuals from several companies, etc.
    We went solar as soon as we put the pool in our house in CT. We have had it for 6-7 years and it has been awesome. We went with a Heliocol system and it can get the pool as hot as you would ever want it. The only issue we ever encounter is making sure that it is fully winterized before it gets below freezing.
