Results 1 to 7 of 7
Thread: Calcium question ??.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Just tested for CH with my TF-100
    It is 100 i have a fibertech coated pool
    Should i try to raise it. Or does it really matter?
    If so whats the best product to use ??
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Feb 2008
    Denton, TX
    5,061
    Re: Calcium question ??.
    You essentially have a fiberglass pool with the Fibertech having been applied. There is no need to add calcium in that situation.
    38,251
    Actually, I thought the CH recommendations were similar to plaster for some reason? They are in Pool School ...
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Wiil low CH cause any problems with my heat exchanger ?
    Sean Hannon
    Feb 2008
    Denton, TX
    5,061
    Low CH is typically not an issue with anything other than plaster. High CH levels can result in scale developing in the pipes of a heat exchanger so you wouldn't want it too high.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Ok..thanks !!!
    Sean Hannon
    Fiberglass will experience cobalt leaching from the gelcoat at low CH levels. We don't really know how important that is, so we recommend CH around 220-320 for fiberglass pools.
