Results 1 to 7 of 7
Thread: removing offline puck feeder?
    Mar 2008
    Lake Forest, CA
    114
    Hello. When my pool was built, the installer plumbed in a Pentair Rainbow 300 offline puck feeder. I don't use it, but I have just left it there because I figured that removing it would involve trying to plug up the installation holes in the pipe, or cutting out sections of pipe and putting new sections in their place. But looking at the installation, it looks like it might be possible to just remove the feeder housing and the hoses, and cap off the connectors that are still installed in the pipe. Is this possible? This way I could always re-connect it again if I decide to use it for some reason.
    If my question isn't too clear, I can post a couple of pictures of the connectors if anyone requests.
    Greg
    12000 gal IG pool/spa combo,60 sq ft Jandy DEL filter,2 hp Jandy Stealth pump,Jandy LX400 400K BTU gas heater,Pentair Rainbow 300 off-line feeder (never gets used),Jandy Aqualink RS4 with PDA remote,3 Jandy 12" sheer descent waterfall features, Dolphin Oasis Z5 robotic cleaner
    38,475
    Re: removing offline puck feeder?
    Why bother to remove it anyway if there is a chance you will want to use it in the future for vacations, etc?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    I'd just leave it be. Can always be used when on vacations.
    Feb 2008
    Denton, TX
    5,061
    I had one plumbed into my system. Once I quit using it, I just left it be until it eventually stated to leak. Then I removed it at that point. It won't hurt anything to sit there idle. You can deal with it once it starts to leak.
    22,553
    A lot of people just remove the canister and hook one of the hoses into the other port. It creates a small bypass in the plumbing, but it's not enough to matter. Or you could remove the fittings, thread the holes for 3/8" NPT and install threaded plugs.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Is it supposed to make noise? Mine sits and sounds like something is rattling inside. Not used, I don't see any air bubble issues.
    IG pebble, 15,000 gallon
    48” PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Jun 2007
    New Jersey
    653
    On my Rainbow 320, I put a threaded cap where the canister screws on and a plug where the hose connects. If I travel for more than one week at a time, I reinstall it. I use the feeder for 1 week and have a friend throw the loaded floater in after 7 days. If I only travel for a week (most years), I just use the floater.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
