Results 1 to 7 of 7
Thread: Simple Salt
    Simple Salt
    Anyone ever heard of a system called: Simple Salt?
    There about 300 bills and I was going to buy a Jandy but wondering if I should try this system. All feedback is appreciated.
    18' x 34' Above Ground Oval w/deep end
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Simple Salt
    I just looked at their website.
    The Simple Salt System provides swimming pool owners with a better quality of water, while eliminating daily usage of harsh chemicals such as chlorine and bromine. Traditional salt systems can cause corrosion to the steel wall and top rails. More and more pool manufacturers will not warranty a pool that uses a traditional salt system. The Simple Salt System utilizes salt in a unique way, simply kick starting the process, to provide better quality water which is also environmentally friendly and safe for your pool. It provides a controlled and testable amount of natural minerals, in this case copper, of which the ideal range is between 0.3-0.5 ppm.
    Shock is necessary with any pool maintenance program.
    Sounds iffy to me.
    I'd buy a plain salt water generator instead. Check out this in Pool School.
    22,553
    Re: Simple Salt
    It's a gimmick. It's a copper system and you still have to shock the pool on a regular basis. You're much better off with a real swg. Read the alternative sanitizer article.
    Re: Simple Salt
    Been looking at Jandy and now compupool. Not sure which compupool to get. Does it matter if its inground or above ground with compupool. The Jandy AquaPure EI is about $475.00.
    38,463
    Re: Simple Salt
    Realize that we recommend you size the SWG 1.5-3 times the size of your pool. So you should be looking in the 30-40k size range.
    Re: Simple Salt
    Yes, was looking at the compupool CPSC24 but not sure if this is for above ground or inground.
    Pool should be 17-18,000 gallons
    38,463
    Re: Simple Salt
    It does not matter ... the only thing affected by AG vs IG is the pump ... nothing else.
