Instructions should have been with your kit, but here is a thread that has them: http://www.troublefreepool.com/water-testing-instructions-on-one-page-t11306.html
??? I'm a bit confused. The laminated card is identical to that link.I did the tests that were on the laminated card and they were right on with the pool store.
woodyp said:Your posts are NOT stupid and noone here considers them to be! Hope you get to feeling better too. The only thing I'd be confident in telling you at the moment is to raise your PH to 7.2 or a little better.
From pool school:
PH can be raised in three ways: borax, soda ash, and aeration. Borax is usually the best choice. Borax raises the PH and also raises the TA level just a little. If your TA level is low soda ash will raise both the PH and TA levels. If your TA level is high, aeration is best as it will not raise the TA level at all. However, aeration is rather slow compared to the other two.
Borax is available as 20 Mule Team® Borax Natural Laundry Booster. It is sold in the laundry detergent section of most larger grocery stores and some big box stores. Borax is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return.
Soda ash is available as ARM & HAMMER® Super Washing Soda Detergent Booster. Do not confuse this with ARM & HAMMER® laundry detergent! It is sold in the laundry detergent section of most larger grocery stores and some big box stores. It is also sold by pool stores under various names, including PH Increaser, PH Up, Balance Pak 200, etc. Soda ash is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return.
Aeration can be provided by a SWG, spa jets, waterfall, fountain, return pointed up so it breaks the surface, air compressor, kids splashing, rain, etc. It can take some time for aeration to raise the PH. The higher your TA level, the faster aeration will work.
Raising your TA is probably very likely needed, but we need better test results. Raising TA by adding plain old baking soda also raises PH.
