Results 1 to 18 of 18
Thread: how to open a stuck AquaRite Turbo Cell
    Los Angeles, CA
    35
    I'm trying to open up my AquaRite Turbo Cell, but neither end just won't budge using hand force. I bought a $10 strap wrench on ebay to see if that would work, but the strap wrench just snapped off.
    Any ideas on how to open one of these things? they're obviously way to big to use like a pipe wrench, so I don't know what other tools I could use to get this thing off
    [attachment=0:9mil3piu]swg cell.jpg[/attachment:9mil3piu]
    IG, pebble tech, approx 20k gallons (33x16 free form) with 3ft raised spa approx 1k gallons & waterfall
    Pentair FNS Plus FNSP60 DE filter (broken), 3 Pentair WhisperFlo WFE-8 2HP 1.30SF pumps (2 broken, 1 leaking a bit when starting), MiniMax N7 gas heater (also broken), AquaRite SWG (it or cell not working), AquaLink RS8 Control, Dolphin Z5 cleaner, TF-100 test kit
    38,295
    Re: how to open a stuck AquaRite Turbo Cell
    I was going to suggest a strap wrench ... maybe get a better on that is less likely to break?
    Sounds like someone put them on too tight in the first place.
    Jul 2012
    Newton NC
    31
    I use a big pipe wrench to get mine open.
    16k 17X33 IG Vinyl(2000), Pentair Intellifo Variable Speed Pump(2006), Hayward Sand Filter, Aqua Rite SWG w/T9 cell(repl 7/2011), Hayward Natl Gas Heater, TF100 w/magnetic stirrer
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have a pair of strap wrenches that I picked up at Harbor Freight for a few dollars. They seem to do the job.
    chiefwej
    Los Angeles, CA
    35
    Yeah, it looks like someone has used tools to tighten/loosen these, even though it says hand tighten in the manual
    Do you know of any good quality strap wrenches? I searched on sears.com & lowes.com and both the craftsman & kobalt have pretty poor reviews and look similar to the "Power Grip" I have tried...
    Los Angeles, CA
    35
    Quote Originally Posted by Saltypool
    There's a ~4" Pipe wrench? Biggest I've seen are like 2.5" tops...
    22,550
    Pipe wrenches are measured in overall length. I've actually used 60" pipe wrenches and they make larger than that.
    Los Angeles, CA
    35
    Well obviously I'm not talking about length, I'm talking about opening width, and a big 18" length pipe typically has a 2.5" opening...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    I'd try some channel locks.
    I have a pair so big they're almost comical. Pretty pricey, though, for a one-time use.
    Los Angeles, CA
    35
    Quote Originally Posted by Richard320
    thanks, I was looking at those types of pliers too but didn't find any the size I need before, but now when I searched for channellock I was able to find a 18" plier at lowes with a jaw opening of 4.25" for 23 bucks... if it works it's worth it! You can never have too many good tools
    38,295
    I think I have that tool!!! I can not remember why I just got it ... might have been to replace the screw in fittings to my multi-valve? Although those are not 4".
    Yukon Jack's Avatar
    May 2011
    Rose Hill, KS
    94
    Try putting on a pair of leather gloves and give it another try - I find that helps get a better grip and ability to loosen that type of fitting.
    18x33 AGP, 17,300 gal, Hayward Sand Filter, 1.5 HP 2 Speed Hayward Pump
    Oct 2007
    Valrico, FL
    542
    Interestingly enough I use two 12" pipe wrenches to loosen mine. You do not need to have the jaws of the pipe wrench open clear across the nuts. The nuts have ridges, and the jaws catch just fine on them.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Ft Lauderdale, Florida
    1,455
    At Harbor Freight, they have Oil Filter Wrenches. This is more like a large curved jaw pliers instead of a band clamp type that fits around an oil filter. Any auto parts store should also have this, but some have them way overpriced. They are about $10.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Los Angeles, CA
    35
    I got the 16" Channellock, and with that badboy I was finally able to open that thing up But even with that huge thing, I still had to crank it to get it open, so it was pretty stuck...
    In the manual it says you're supposed to check the plates and clean them etc. I rinced through it with the hose and got some gunk out of there, but through that little hole I can hardly even see the plates, only the rows of white plastic that I'm guessing are holding the plates somewhere in the middle... So how are you supposed to inspect the plates inside?
    38,295
    You would be able to tell if there was a lot of buildup between the plates ... if you can see through there, then you are are pretty good.
    Los Angeles, CA
    35
    Ok sounds good, thanks!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yeah, just hold it up and look through the whole tube.
