Results 1 to 9 of 9
Thread: . Is Aqua Perl a Diatomaceous Earth DE Alternative
    I have a Hayward EC65a filter. I am about to load it up for the season and need to ask the question . . . Is Aqua Perl a Diatomaceous Earth DE Alternative and Replacement? I have read about safety issues with DE and have to make a purchase soon.
    I used the BBB method last year for the first time ever and loved the results . I will do what you advise.
    I live in Lynchburg, VA. and have a vinyl 16x32 in-ground pool with avg. depth 6.5'. 26500 gallons.
    Tri-chlor 3" tabs, bleach, Arm and Hammer soda, muriatic acid, Flo-tron ionizer, solar cover, Hayward D.E. filter, Hayward Chlorinator.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: . Is Aqua Perl a Diatomaceous Earth DE Alternative
    Yes, it is a replacement. I just did a search on this website, and there hasn't been much discussion on it.
    I nominate Guffey Guy to be the guinea pig for this product and report back to us at regular intervals. Who'll second it?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Guffey Guy
    Second
    As Richard mentioned we have not had much feedback on it. If you do try it, please let us know how it works.
    Here is one thread: http://www.troublefreepool.com/using...-e-t20136.html
    Well, gentleman, I see where it has been first and seconded to go the Aqua Perl route. I will be glad to give it a try. Thanks
    38,305
    That's the spirit!!! ... contributing to the collective knowledge within the first few posts
    Richard320's Avatar
    Jan 2010
    19,023
    Quote Originally Posted by Guffey Guy
    [center:15fx2hjz]Take heart!
    [youtube:15fx2hjz]Xa6c3OTr6yA[/youtube:15fx2hjz][/center:15fx2hjz]
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I too have considered trying a DE alternative, however when I contacted Hayward about the use of DE alternatives, they strongly urged me not to use any DE alternative in a Perflex type DE filter.
    Jun 2007
    New Jersey
    653
    I've been using AquaPerl in my Waterway DE filter for several years now. It seems to work just as well as real DE. I think I posted in a thread on it a long time back but it didn't get much attention.
    EDIT: Here it is: http://www.troublefreepool.com/using...-e-t20136.html
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    May 2012
    Long Island , NY
    15
    I just started using as a result of my pool store stocking it instead of standard DE. I have a Hayward EC-50 filter. It seems to filter good but when I re-generate (bump) the filter, I get a plume of cloudy water which I assume is the aqua perl coming out of the outflow for a few seconds. I think that I am going back to the standard DE to see if it happens then. - John
    18 x 33 x 54 Brothers Three Sharkline Navigator Above ground pool with Hayward EC-50 perflex earth filter with 1 hp motor, Hayward H series Low Nox 200 FDN heater, Hayward AquaTrol SWG. Pool was installed April 15, 2015 to replace an existing 30 year old pool that self destructed due to the hard Long Island freeze we experienced this winter.
