Thread: First time grilling ribs
    eap2313's Avatar
    Apr 2013
    Lewisville, TX
    37
    Yesterday I took my first stab at spare ribs on the grill. Soaked in apple juice, used a 9 spice rub, and apple cidar vinegar to mop (simply used a spray bottle). The oven thermometer I used read about 190 degrees, but I'm sure my grill was hotter than that as the rack finished in 2.5 hours not including a 20 minutes foil covering with the bbq sauce applied. Used hicktory chips to get a nice smoke and indirect grilled on a 18.5" CharBroil coal grill. Plan to use the drippings to marinate some wings. Wife loved them so all is good in my life, lol.
    16K gal Plaster Pool (built approx. 1999)| 2HP Purex Triton WhisperFlo Pump | Polaris PB4 Booster Pump | Purex Triton Sea Horse Cartridge Filter FSH 500 (DE grids inside) | Hayward Vari-Flo Valve | Compool 3-Way Valves | Chlorine/Bromine Feeder Model 320 (Rainbow Lifegard) | Laars Lite Heater | Whisper Jet II (Tropic Air) | 6'9" x 6'9" Spa
    Dallas-Ft. Worth Metroplex
    Jan 2011
    Richmond, Texas
    595
    Re: First time grilling ribs
    Looks good to me!
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yeah...with the grill temp at 190, they would have never finished. If they were done in 2 hours, you were somewhere above 300..maybe up closer to 400.
    Check out bbq-brethren.com ....it changed everything for me!
