Thread: Solar Reels. . .Pros and cons
    I am looking to buy a Solar Reel and cover for a 16x34 pool. I have been reading the posts on the covers, but little or nothing about the reels. Are there reels to just stay away from because of construction and materials? Is there a consensus on a reel or reels that do the job as advertised?
    I live in Lynchburg, VA. and have a vinyl 16x32 in-ground pool with avg. depth 6.5'. 26500 gallons.
    Tri-chlor 3" tabs, bleach, Arm and Hammer soda, muriatic acid, Flo-tron ionizer, solar cover, Hayward D.E. filter, Hayward Chlorinator.
    Re: Solar Reels. . .Pros and cons
    I bought a cheapie reel from a discount pool supply website last year. It works fine; my biggest complaint is that it's an eyesore on my deck, and the solar blanket doesn't seem to make much difference in my water temp.
    14k gallon oval agp, sand filter, 1hp pump, BBB method, K-2006 Test Kit
    Roanoke, VA
    Thanks for the reply. I have a sungrabber solar panel on my roof that is used to heat the pool also so what I'm going to try to do is use the liquid heatsaver product for the season and see if that does the same job. I think I got between five and seven extra degrees last year from the solar panel. If heat saver can give me another 4 or 5 I'm fine with that.
    The reel and cover package was almost $600 which is at this point not necessary. I'll just figure it out at the end of the season see which way I must go
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by karmazrevenge
    Having a solar blanket on a night can/should make a big difference. Most of it due to reducing heat lost due to evaporation.
    On my pool, somewhere around half of my heat gain is due to using a cover a night and the other half is due to using solar panels.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    $600 is crazy! A cover should be <100, and a half-decent reel maybe 200. The Rocky's ones are nice, but the less expensive ones are fine too.
