Results 1 to 10 of 10
Thread: equipment pad
    equipment pad
    i do have to provide a pad for filter and pump to set on. guy at pool store said to get some paver stone what are your guys thoughts on this stone airconditioner pad or what ?
    15x30x54 AG,2HP2SP PUMP 400LB SAND FILTER
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: equipment pad
    Quote Originally Posted by wildwilly1
    Hard to get a paver level and have it stay that way for years. I'd pour a pad. I think they sell plastic forms for pouring AC pads. That's what I'd use.
    Re: equipment pad
    thats what i was thinking thx
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: equipment pad
    I agree poured pad, and the more spread out your equipment the better when of comes time to do maintenance, also I would require all pieces of equipment to be connected with screw together PVC Unions. It may add $30-$40 now, but will save lots in the future when it comes time to replace pumps, filters, valves, etc.
    Re: equipment pad
    i was thinking how i could figure out where to pour pad until they install the pool i want it close to pool they will have to do some digging to install pool i dont want it in the way nor do i want it too far away
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: equipment pad
    Do you already have electricity to the site? If so you likely want to locate your pad near where the electrical service already exists, either way you will have trenching, but plain PVC pipe tends to be a lot cheaper than PVC conduit, plus copper wires, and paying an electrician to pull them.
    Re: equipment pad
    YES I ALREADY HAVE ELECTRIC RIGHT BESIDE POOL GOING INTO A GARAGE SO I CAN JUST PLUG THE PUMP IN TO THAT ALREADY AN OUTLET THERE OUTSIDE
    Mar 2013
    Sayville, NY
    53
    Re: equipment pad
    Can't you pick up a pre fabricated concrete pad? They are like 4x4 and 2 inches thick. I think they have them at home depot and Lowes.
    16 x 32 Vinyl IGP ~22000 G
    Re: equipment pad
    DID NOT KNOW THEY MADE THOSE I WILL HAVE TO CHECK THX
    Rick H's Avatar
    Jan 2013
    Liverpool, NY
    45
    Re: equipment pad
    I picked up two 2ftX3ft patio blocks and placed them on top of a base of leveled crushed stone. Seems to work good, plenty of room for the pump, cartridge filter, chlorinator (which I won't be using anymore!!) and all the PVC piping. Home Depot and Lowes should have them. But, they are heavy!!!
    Upstate/Central New York. Roman style IG fiberglass pool, 13X33, 8800 gallons, installed July 2012. Pentair cartridge filter, 1 hp Pentair single speed pump. Taylor K2006 Test kit. Went BBB route in spring of 2013, no problems, no regrets!!!!!!
