Thread: Hole in wall of pool
    Found hole in the very bottom of the wall of my pool. No water is leaking out. Having a new liner installed what do I use to patch the wall? JB weld?
    30,403
    Re: Hole in wall of pool
    Welcome to the forum. What's the wall made of?
    Metal I guess,
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    With the old liner out take some metal flashing and tape to the inside of the wall at that point. Use duct tape on the edges to protect the new liner. The bottom edge of the flashing may fit into the wall track at the bottom. Water pressure will hold it in place. If there is any rust sand and paint first.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
