Thread: Skimmer location
    Skimmer location
    Does the lid behind a skimmer need to go in a deck area or can it be in a planting bed? We have several planting areas around our pool and both skimmers are on the border of deck and planting area. Is it better (or even mandatory) that there is deck around the skimmer or would it be ok in a planting bed. Deck is going in this week. Pavers.
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    Re: Skimmer location
    The skimmer doesn't have to be in a deck area, but keep in mind that you will be leaning down to reach into the skimmer and pulling out leaves and other debris quite frequently, which could easily cause damage to nearby plants.
    Thanks! It does not look like the lip on the clean-out hole comes up to deck height (my coping is about 3"). Are there extensions that can be used to bring the lid up to deck height, or above the dirt level in a planter?
    Feb 2012
    Maryland
    400
    Quote Originally Posted by jtech1
    There are extenders, look at the last pic in this thread that looks like a big white pvc piece. Its an extension for a skimmer.
    http://www.troublefreepool.com/diy-u...t57808-20.html
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
