Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Cloudy Water
    Cloudy Water
    Im clueless about pools, this is the second year owning a home with a pool. Just found this site, it would have been very helpful last year. Ive battled green algea while opening my pool this year. The water started out a dark green/brown color. Ive got it somewhat cleared up and its now a very light blue. The problem I have now is that its very cloudy. I've tried a sink and sweep product and it didnt seem to make a big difference. What is the best way to clear the water? Ive backwashed the filter many many times, sweeped and vaccumed the pool at least a dozen time since I started to open it last week. I have also added about 15 lbs of soda ash bc the ph was very low at first. Thanks in advance for your help.
    My test results are:
    total hardness 250
    total chlorine 10
    free chorine 20
    ph 7.0
    akalinity 130
    cya 75
    Andy McManus Augusta, GA
    15x30 IG, Hayward Pump, Hayward Clorinator, Baker Sand Filter
    22,551
    Re: Cloudy Water
    Welcome to TFP.
    Where did you get those test results?
    You can't have FC higher than TC.
    The first thing you need is a good set of test results.
    Just keep running the pump and filter.
    Re: Cloudy Water
    Welcome to TFP!
    Even if you have killed all of the algae, which isn't obvious at the moment, it can still take a sand filter another week or two to clear up the water. If the algae is all dead you should see a visible improvement in the water from day to day, though it might only be a very small improvement.
    Also, you need to be careful about adjusting the PH when FC is high. FC above 10 can invalidate the PH test results.
    Re: Cloudy Water
    My test kit cl reading only goes up to 10 for total chlorine. It doesn't test for free. I also have some aqua check 7 way strips. That's where I got the free chlorine number.
    Feb 2008
    Denton, TX
    5,061
    Re: Cloudy Water
    Welcome to TFP!
    We will get you going in the right direction. First though, you will need to get a good test kit. We recommend the TF-100 from tftestkits.net, as it has all of the tests that you need and is an excellent value. You can also get the Taylor K-2006 which is good too, but much more expensive than the TF-100. You won't be able to find either kit in the pool store. Anyway, once you have your test kit, you can run the tests and post the results. Then, we can get you squared away.
    Re: Cloudy Water
    Will do. Thanks
    Re: Cloudy Water
    Alrighty, kit came in today. Blows my old kit out the water. Here at the results
    ph 7.5
    fc 15
    cc 2
    tc 17
    ta 120
    ch 320
    cya over 100 ( it was below the 100 mark when the dot went away)
    It is still getting better a little bit each day but still cant see the shallow end bottom.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Cloudy Water
    Cloudy water with CCs above .5 means you need to shock. However, shocking with a CYA above 100 (and we don't know yet how high above 100) is almost impossible. You are probably looking at a significant drain and refill.
    Can you redo the CYA test with half pool water and half tap water? That will give you a better idea of what CYA you're looking at.
    Re: Cloudy Water
    Redid the test with just pool water, still below line. With half and half it measured about 55. So does this mean the cya of my pool water is around 110? Is that still too high to shock?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Cloudy Water
    Yes, 110. We would recommend getting the cya down to 50 ppm before doing the shocking process, unless that chlorinator you listed in your sig is a Saltwater chlorine generator? If it is, then get your cya down to 70-80 before doing the shocking process.
    Re: Cloudy Water
    It's not salt. It's an inline tablet chlorinator. What's the best way to lower it?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Cloudy Water
    Draining and refilling is the only way to lower CYA.
    Re: Cloudy Water
    Ok. Guess ill bite the bullet and do that. How much should I drain? I only have one skimmer and don't have a pump.
    30,426
    Re: Cloudy Water
    Siphon it with a hose. If you replace 50% of your water, your CYA will drop by 50%.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Cloudy Water
    What kind of pool surface do you have?
    Re: Cloudy Water
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Cloudy Water
    Don't let the water get below a foot deep in the shallow end to protect your liner.
    If you have a main drain you can run your pump to waste. Siphoning is a bit harder for an IGP. Last option is a submersible pump, either bought or rented.
    Re: Cloudy Water
    I don't have a main. Only skimmer. I will try to siphon when I get home
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Cloudy Water
    I have an above ground, so my usefulness has just run out (until you're refilled and ready to shock....then I'll jump back into the fray!).
    Anybody else have any suggestions other than multiple drain/refills?
  20. Back To Top    #20
    Re: Cloudy Water
    Quote Originally Posted by Smykowski
    Submersible pump from Harbor Freight. Should run around $50. That or backwashing/wasting to the inlet level and refilling are really the only options.
