Results 1 to 7 of 7
Thread: PDA won't activate "cell on"
    Jandy aquapure 1400 3 port cell. So my sensor is new, my PDA works properly(enough), my control board has power, flow, salt is at 3400, no codes. "Cell On" doesn't happen from the PDA program. In service mode everything works and displays great. This is an inherited pool and everything seems to be functioning otherwise. I'm stumped. Everyday I am putting it in service mode to generate chlorine, since I realized last week that my water was cloudy. Oh and my chemistry is pretty good too.
    jkurl's Avatar
    Fairfield, ca
    141
    Re: PDA won't activate "cell on"
    Quote Originally Posted by Cochise
    Try running a diagnostic from the PDA to see if it a truly working correctly. Check your connects just to be safe and the other thing you might try are replacing the batteries in the PDA and the 9V is the panel. I have seen my PDA act weird when the batteries are low. The next thing to try is delete the cell on program and the. Re-add it and then see if that might help you. What you could do is delete the program and to get it add it back in and set it for 5 mins from when you added it in I.e. if it is noon when you add in the program make it start at 1205 to test the program and if it works delete it and add in your normal time.
    Pool Size: 20 x 40 Free Form Inground Plaster Pool w/ a shallow cove.
    Gallons : ~23K Jandy CL580 Cartridge Filter, Jandy e-pump 1.5HP
    Polaris 280 w/ Booster Pump, AqualinkRS PDA4 Remote, Aqua-Pure SWG
    Jandy LED Pool Lights (2), Heliocol 500 Sq. Ft solar rack system
    Well diagnostics are fine batteries are new and deleting and changing program did nothing. M " delete cell on program"??? There is no cell on, on the PDA program that I am aware. The chlorine cell comes on with the pump program, that's why the aquapure is displayed in percentages. Am I missing something on my PDA display?
    jkurl's Avatar
    Fairfield, ca
    141
    No your not messing anything. I just used cell on from your post. The pump program is what I meant. If you had a aquapure 1400 before it should work fine unless you had something else going bad the same time the other cell went bad.
    Got a question. Is this a new install or have you just replaced the cell?
    Cell is older date unknown. Again it works in service mode. It's the sensor thats new.
    jkurl's Avatar
    Fairfield, ca
    141
    The only thing I can think of is either loose wiring or the aquapure board in the control panel went bad. Can you take a video of it running in auto mode and then switch to service mode and then switch back to auto. It will give me a better idea of what your panel is doing. The manual states check the wiring which it could be that cause service mode locks the pda out of the system.
    Sep 2016
    Destin, FL
    4
    Did you ever find a solution? I am having same problem. Changing % on PDA does nothing. I have to change from the control box.
