Thread: Hayward PowerFlo Matrix 2 Speed Pumps
    Does anyone have the specifications for the Hayward Matrix 2 Speed pumps. It seems Hayward doesn't advertise amp draw for each speed or rpm. Even approximate GPM would be good.
    I'm looking at the 3/4hp and 1hp models.
    Thanks
    18' x 34' Above Ground Oval w/deep end
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Hayward PowerFlo Matrix 2 Speed Pumps
    I have 1hp 2 speed. Hayward told me on low speed it's rated at 20 - 30 gpm at 10ft of head. Amps I don't know.
    Jeff
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I have the 1 hp Matrix 2 speed. It is rated at 11.0 amps on high 2.9 amps on low (these are the theoretical on label values). On my pool with about 47 ft. of total head loss, I get about 45 gpm. It is a lot of pump on high, almost too much for my filter.
    I don't believe hayware makes a 3/4 matrix 2-speed.
    What do you have for a filter?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    It'll move some water on high for sure. I use low speed 95 percent of the time. I'm very happy with it.
    Jeff
    Sta-Rite T-200-BP1, 2.18sqft. Sand Filter.
