Thread: Muriac acid application
    The directions always say put into a 5 gal bucket and then the pool. Is that just for safety so there's less chance of spilling on yourself, or is there another reason for the directions?
    36K gal, gunite w/ plaster,[18W x 38L x 8 deep end] 300SF cartridge, 80-100 GPM filter, Sta-rite S7M120 and Polaris 9300 electric robot. Rooftop 6 panel Solar heater, Sacramento Valley, Climate Zone 8
    30,421
    Re: Muriac acid application
    Just safety..... but I like this.
    Kneel by the pool in front of a return..pump running) and lower the bottom of the container into the water so it almost floats. Then, slowly tip the container to smoothly release the acid. I would do it with a suit and tie (if I owned a suit and tie). There is no spill
    PS - if you have an AG pool and no decking, kneeling will make it VERY difficult
    Apr 2012
    SW Ohio
    456
    i use a measuring cup to make sure i am adding the proper amount per the pool calculator, and if you add it to a bucket you are doubling your chances of getting it on you. just pour it slowly in front of the return just above water level....ohhhhh and BTW you might want to hold your breath.....lol
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Quote Originally Posted by fast1971chevelle
    Yes, definitely check which way the wind is blowing before you uncap the acid.
