Results 1 to 9 of 9
Thread: Water level went down?
    lynns's Avatar
    Jun 2010
    New Jersey
    50
    I just peeked under the cover. It looks like the water level went down a couple inches over the winter. Is this normal?
    14x30 Viking "Santa Barbara" Fiberglass Pool 12,500 gallon
    IntelliFlo Variable Speed Programmable Pump
    Salt Water Generator with AquaRite Electronic Chlorinator
    Pentair Clean and Clear Cartridge Filter
    22,553
    Re: Water level went down?
    A couple of inches is nothing around here. Evaporation will account for that much. Even with a winter cover on.
    lynns's Avatar
    Jun 2010
    New Jersey
    50
    Ok good. I guess I thought that since we had such a wet winter (even a hurricane), that the water level would have risen not gone down. Good to know that evaporation will happen even with the cover on.
    I'm in New Jersey as well, and my water was much higher than when I closed. When I closed, it was below the skimmer boxes. When I opened it was also above the top of the skimmer box. I have a mesh safety cover... not sure what type of cover you have, but you may want to keep an eye out for a leak.
    30,000 gallon vinyl pool
    Hayward DE Filter
    Hayward Super Pump
    AO Smith 1 1/2 HP Pump (27GPM)
    Polaris 380 Pool Cleaner
    Check out the app I created to control my pool equipment from my smartphone:
    i-created-an-app-to-control-pool-equipment-with-smartphone-t61606-20.html
    Same here in NJ -- Water was at top of my skimmer due to the heavy rains over the last couple of weeks. I had to lower the water right after opening.
    35K Vinyl IG | 1.5 HP Hayward Superpump | Pentair TA60D | Dolphin Dynamic
    lynns's Avatar
    Jun 2010
    New Jersey
    50
    Where could it be leaking from when the pool is not running and water is below the skimmer?
    I would think liner / main drain / pool light are all candidates.
    Jun 2012
    Howell, NJ
    977
    I wouldn't think it is a leak. I am also in NJ, and have lost a few feet of water. I have a solid winter cover, but water from the pool comes through and with the hot days we had a few weeks ago, evaporates.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    Just pulled my winter cover off tonight and water is much lower than it was last fall when I closed...I'm sure the 12"+ of water I had to pump off the cover was the culprit as well as evaporation.
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
