Thread: Opened today
    Sep 2010
    Noblesville, IN
    104
    Opened today
    Cleaned off the top of the cover, pushed the button to open the automatic cover, replaced the plugs with eyeball jets, had the DW get a few leaves out of the pool, replaced the pump and filter plugs, turned on the pump did a little priming and everything came on and I was Happy, Happy, Happy!!!
    I am gonna let the floor cleaner run and see what vacuuming I will have left.
    First numbers-drum roll please...
    FC-6
    PH-7.5
    TA-90
    CYA-40
    I could swim today...if the water wasn't 55 degrees.
    Kudos to this forum. I'm starting to get this stuff figured out..
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    30,431
    Re: Opened today
    Kudos to this forum
    Mostly, kudos to you for taking the time to learn how to manage your pool water.
    (55?? Brrrrrr!)
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Re: Opened today
    55!.... thats almost balmy! Mine was 51deg... it was almost painful screwing those eyeballs in. Congratz on the easy open!
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
