Thread: Kreepy Krawly vacuum problem
    May 2012
    Dallas, Texas
    47
    I ran my vacuum yesterday and it was working fine. Today I put it in the pool and it isn't moving. It has suction (sticks to the bottom) but it doesn't have the familiar clicking sound. I adjusted it to maximum suction and minimum suction with no change in results. Has anyone experienced this issue?
    15,200 gallon 24' X 52" round AG; installed 2011; SWG
    1 hp Dynamo pump; Pentair Meteor sand filter, 2.1 sq. ft. filtration area, 42 GPM flow rate
    TF 100 Test Kit
    lewistonpool55's Avatar
    Jun 2012
    Lewiston NY
    15
    Re: Kreepy Krawly vacuum problem
    Try moving the weights around to different spots on the hose. The balance sometimes effects it.
    28,000g IG
    Jacuzzi Pump and Sand Filter
    May 2012
    Dallas, Texas
    47
    Vacuum's working. No particular reason.
    TF 100 Test Kit
