Thread: help hayward ec75a filter
    Hayward recommended this filter for my inground 22,000 gal pool. I am only getting 2 months between total cleanings. This seems too much. The back charge does not buy me anything. The filter when opened shows very little algae and the tubes rinse to white with plain water. The pump is a 1 hp, but stops pumping water through after 7-8 weeks. I rinse, drain, recharge de and it works great for 2 months. What am I missing here? The pool is not used very much at all, and chlorine and shock is done regularly. Help.
    38,371
    Re: help hayward ec75a filter
    Welcome to TFP!
    You should never be seeing algae in the filter. My guess is that you are not maintaining a high enough FC level.
    Some reading in Pool School (button at upper right of page) will give you a better idea of how we recommend maintaining your pool ... this is not what you are doing as we rarely have to "shock".
    Please post up as full set of test results.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One more filter specific thing are you using pool DE and are you carefully weighing the amount used?
    Thank you for your help. My FC was off and I found a loose connection which was allowing air in the system.
