Results 1 to 14 of 14
Thread: Need new Pump
    Need new Pump
    Hello,
    My current pool pump, sta-rite 1hp (K48K2PA105C1), is making a high pitched whining noise. I gather from other posts that it is likely a bearing issue. In any case, I am taking this opportunity to get a new more efficient pump.
    My in-ground pool is 14,000 gallons, has 1.5in pipe with a bottom main drain, skimmer drain, and a port for a vacuum that I do not use. I also have a solar water heater system that is on the roof of my one story home (maybe 20-25ft high?). I use a DE filter, Pentair fns plus 48.
    I was wondering, based on the above information, what pump size and type I should get? My main goal is to install the most efficient, cost effective pump that would maintain my pool. I understand that the variable speed pumps are great at saving power, but I wonder if a correctly sized two speed pump would be more economical.
    Any advice or guidance would be greatly appreciated. Thanks in advance for you time.
    30,421
    Re: Need new Pump
    Welcome to the forum.
    I agree. A 2 speed will be quite a bit cheaper overall and, unless you live where electric is sky high, it's hard to get your money back on a VS pump.
    A full-rated 2-speed 1 hp would be a good fit for your pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Need new Pump
    Welcome to tfp, jstgtpaid
    The model number you posted was for the motor. Is there a model number for the whole pump visible?
    Re: Need new Pump
    It is the sta-rite Max-E pro.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Need new Pump
    How about replacing the motor with a 2-speed, so you don't need to redo plumbing. I think A.O. Smith UQS1102R would be a 2-speed version of your motor (though it only comes as 230 volt). What is your voltage?
    Re: Need new Pump
    I checked the voltage and it is 115v. Do I have any other options for motor replacement?
    Also, does 1hp seem like the right power for my setup or can I get a lower power pump?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Need new Pump
    There is this motor: A.O. Smith B2981T that seems to fit the bill.
    It is supposedly 115 volts with an integrated timer. Not sure why this isn't available without the timer? Maybe mas985 knows?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Need new Pump
    I just sent mas985 a pm to take a look at your thread and this new motor suggestion.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Need new Pump
    The B2981T comes with a timer. The B2981 is without the timer.
    http://www.inyopools.com/Products/00200017039441.htm
    This two speed is a larger diameter so check the motor support and make sure it has a piece that can be removed near the back end of the motor to accommodate a larger diameter motor. I don't think the Max-E-Pro has the spacer.
    Mark
    May 2008
    Northern California
    72
    Re: Need new Pump
    Another base option is part #C104-79P. This is the base for the 3hp Max-E-Pro which uses a 56Y size motor.
    12,000 gal. IG Colorquartz, 1.65hp Sta-Rite with 2-spd motor, 300sf cartridge, disabled SWG, AquaLogic P4, Polaris 280, gas+solar, 6' sheer descent with dedicated pump
    Re: Need new Pump
    So I could purchase the 2 speed motor, B2981 , and the base part #C104-79P and I should be good? should I replace any other gaskets, seals etc, while I have it open?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Need new Pump
    Yes, you should get a seal kit and replace all the seals and o-rings.
    Mark
    Re: Need new Pump
    I see tons of different kits and seals. Would you have a part number so I know that I am getting the right one? I appreciate your help on this.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Need new Pump
    According to this it is a Go-kit 38 but I would check with them just to make sure. It looks like it depends on the manufacture date of the pump:
    http://www.a1poolparts.com/-strse-Pumps ... gories.bok
    Mark
