Thread: Teflon tape vs Plumber's pipe dope ?
    Reading through my Hayward Power-Flo Matrix installation booklet under the Plumbing section it says
    Use Teflon tape to seal threaded connections on molded plastic component. All plastic fittings must be new or thoroughly cleaned before use. NOTE: Do Not use Plumber's Pipe Dope as it may cause cracking of the plastic components
    Teflon tape does not always give you the best seal as well as the plumber's dope does!!
    Has anyone had any experience using pipe dope instead of Teflon tape on the plastic housed pumps and any other plastic to plastic fittings?
    24' Round Doughboy 52" height, 1HP Hayward Power-Flo Matrix, Doughboy sand filter
    Location--Charleston S.C
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Teflon tape vs Plumber's pipe dope ?
    I use dope on some fittings. If you do, make sure it is labelled for use on plastic pipe.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    I use the white ptfe pipe dope with no issues whatsoever
