Thread: Return Fitting replacement
    Mar 2012
    Lewisville, Texas
    71
    http://www.youtube.com/watch?v=-3NyFXYK7E0
    InfusionPool Products - How Our V-Fittings Work
    Looks pretty cool. Anything wrong with them? Asking because I broke one of my eyeballs trying to adjust it. Is it likely I can change it on my own? Also do I need to drain the water below the return fitting to replace it?
    http://www.inyopools.com/HowToPage/how_ ... _jets.aspx
    This guide says to use an adjustable grip wrench with a rubber adjustment strap. The one in the picture looks good. Where can I buy a good one? Or should I say reliable without costing all that much.
    I suppose I'll know if I can do it myself if the fittings turn with one of these wrenches.
    Also on another thread someone mentioned turning the Jandy Valve with the pump off. Is it a really bad thing to turn it with it on? I've been doing that quite a bit. Wonder if that has something to do with my pump not priming.
    I've been using my cleaner to clean the bottom and the pump basket fills with leaves. I remove the leaves and restart the pump and it doesn't want to prime. Could switching the Jandy Valve while its on have caused it?
    Lewisville, Texas 22,000 Gallon IG Plaster Chlorine FNS Plus Vertical Grid D.E. Filter 60 sq. ft. 150 GPM Push/Pull Valve Hayward Ecostar SP3400VSP Baracuda Zodiac G3 Cleaner
    Caldera Vacanza Marino Vanto Spa VMA4R6393
    Feb 2008
    Denton, TX
    5,061
    Re: Return Fitting replacement
    Never seen those V fittings. Interesting.
    I just use a set of channel locks to get the old one off. Then I just screw on the new one by hand.
    Mar 2012
    Lewisville, Texas
    71
    Quote Originally Posted by 257WbyMag
    I can't seem to turn it with channel locks so maybe they are glued in. Either that or disuse has made them not want to turn. I've heard some people glue them in or something. It sounds stupid.....but I've heard about it being done.
    Also can you confirm if you can do this without draining the water?
    Anyone have a good guide on checking the pump for issues? Simple issues I don't want to get into resealing things and such. Someone mentioned having something in the impeller and checking it.
    I don't know where this stuff is, but I'm sure there are diagrams. I'm going to google for now see what I can find.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    It's a Rubber Wrench. I found mine at Lowes. I use it on pump connections that have the intex type screw on connections and on the intake and return fittings.
    I wouldn't think you'd need to drain the pool but it might be easier if you turn off the pump. Only so you're not fighting the return flow pressure while trying to align the threads. If you have salt water, rinse and lube the wrench hinge when your finished or the metal pin will rust.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
