Thread: Why running a SWG in day time is better than at night?
    Mar 2013
    Bangkok, THAILAND
    18
    I'm confusing after reading pool school section. I know that sun light consume chlorine, so why should I run my SWG at day time? Is it better to run in late evening and leave chlorine to work all night?
    -26 Cubic Meters (6,868 Gallon) On Ground Concrete pool with epoxies paint finished.
    -EMAUX FSF 400-6W Sand Filter&Pump Combo 6.48 Cubic Meters/Hour (1,711 Gallon/Hr)
    -EMAUX SSC15-T Salt Chlorinator (Cell output 15 g/hr)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Why running a SWG in day time is better than at night?
    During the day the sun is using up the available chlorine whether the swg is on or not, so it is then when you need to maintain a high enough FC level so that algae won't start (the sun is also fueling any potential algae). At night, unless there are swimmers or other organics in the pool, there is nothing using the chlorine so your level should maintain without the swg.
    38,290
    But, as long as the FC never drops below the minimum, then you can run the pump when you want. Especially if your power is cheaper at night.
    Just verify in the evening before the pump comes on that the FC is still high enough.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Mar 2013
    Bangkok, THAILAND
    18
    Thanks linen , jblizzle. I think my confusion is that I think chlorine kill algae, but it seam like what we want is to prevent algae to start.
    Then the trick is do what ever not to lower FC below the minimum. I think I got it.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    The key is the early evening test right after the sun has gone down. Without the SWG running during the sunny hours, this is when your FC will be at its lowest. My parents run their SWG up until Noon, when their electric rates take a jump. They have had to experiment with run time and duty cycle to get their minimum FC needs to be met consistently.
    I am on a level rate plan, so I just run. Mine from 7:00 am until 5:00 pm.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Good points! High peak electrical rates might be a good reason to run off-peak (we don't have that issue here). In the end, as long as the minimum FC (swg) level is maintained, all should be good.
