Thread: intex PVC hard plumbing
    Apr 2013
    Southern Indiana
    4
    I am currently hard plumbing my new sand filter to my 16x48 Intex pool, including adding a thru wall skimmer. I have done a lot of research on this before starting the project, which led me to join this group. I'd like to thank everyone for posting such valuable knowledge.
    So I'm adapting 1-1/2" PVC to the intex fittings. As many have pointed out, Intex uses non standard thread size. I have made a discovery that i haven't seen anyone post yet. I cut the thin plastic Intex hoses off flush with the (non standard thread) fittings and found that the 1-1/2" PVC fittings(coupler,elbows ETC) will slide onto the Intex fitting. Its a tight fit, and you'll have to be quick once the cement is applied. It helped a lot to "dry fit" each one into the fitting first to kinda "pre-taper" the intex fitting.
    This eliminates some adapters and shaving fittings that others have done.
    Jason
    16 X 48 Intex Ultra Frame(6900 gal.), 2650 GPH Intex sand filter, thru wall skimmer and PVC plumbing upgrade
    Apr 2013
    Southern Indiana
    4
    Re: intex PVC hard plumbing
    I should add this note. Dont forget to put the nut on the Intex fitting before gluing it to the PVC fitting
    I also used flexible PVC "spa hose" to eliminate the need for multple 45 degree elbows to bend around the pool with hard PVC pipes. The spa hose is just as thick and strong as the PVC pipes. Its available at Home Depot, Lowes ETC. A bit more expensive, but I got mine from work for free.
    Also this:
    I eliminated the "extra hole" problem by installing the thru-wall skimmer where the original return jet is. The skimmer is a "hydro tools" brand, exactly like the Hayward most people are using. I made my new large square skimmer hole so that the bottom of the square hole lined up with the bottom of the original round hole. Just so happens to work out so the top of the square hole is just under the top seam of the liner. My return jet will now be where the original intake port is. This reverses the intake and output on the pool itself, and lowers the jet, but I don't mind. I'll just aim the jet upward more to point the flow to the water surface.
    Jan 2013
    Aruba
    229
    Just found this post,so if i understand you cut the intex coupling before it turns in to flex hose and you just glued a 1.5" pvc coupling?
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
    Apr 2014
    FOUR cORNERS
    111
    could you please post pics
    I cut a couple to try this. A little snug is an understatement. I'm not saying you can't, but it was well worth the $1.25/box end fitting IMHO to be done with it. I don't think I could have gotten them on in time with glue...I could barely fit it on with a screw driver prying.
    Oklahoma
    30X20 Gunite pool completed in July 2013
    Jun 2016
    Pittsburgh, pa
    367
    I'm trying to figure out where you guys are getting the threaded adapter that you replaced the plastic tube with on the outlets on these mods..
    Its my understanding you just re-used the hole and shoved this threaded thing inside the hole..
    Can anyone post pics or show the thing thats in the hole from both sides or a link to amazon etc where you can find it?
    Not sure what the alternative is here to this setup.. i see mentions of the box adapter, but it still presents the same issue, there is no threading on the default outlet port to attach to from a pvc/box adapter threaded 1.5 ring setup?
    Thanks
    My Intex Ultra 18'52 build
    My SmartPool Solar Panel Build
    6981 Gallon + Hayward 1.5HP Matrix + 21"
    Solar S601P SmartPool 160sq feet solar panels
    Intex 7K Gallon SWG, Hayward WideMouth
