Results 1 to 11 of 11
Thread: Can't get pool clear
    Apr 2013
    Arkansas
    5
    We are first time pool owners (moved in November) and pulled the cover off 2 weeks ago. It was a swamp and we have been skimming, adding chlorine, stabilizer and we just can't seem to get the water clear. It's not green anymore, just cloudy. Here are our levels as of tonight:
    FC = 13
    CC = 1
    CYA = 35
    pH = 7.2
    The bottom is clear of debris, but we can see the dead algae on the steps. Last weekend we put water clarifier. Today we put sad filter cleaner in. We are buying chlorine at SAMs by the gallon and adding every 1-2 days; the FC level has been between 13-15 for the past week.
    Advice?
    Re: Can't get pool clear
    Welcome to TFP!
    It sounds like you are making good progress and almost have it licked. At this point you should be seeing some improvement in the water each day, even if it is a very small improvement.
    What kind of filter do you have? How has the filter pressure been behaving? Have you been cleaning/backwashing the filter and if so how often?
    Apr 2013
    Arkansas
    5
    We have a sand filter, up until the past 2-3 days backwashing every 8 hrs (5-7 psi increase) now 1x day 2-4 psi increase also brushing daily and there is visible dead (brown "dirt") algae on the steps. Brushing to the deep end. Appreciate your insight and assistance
    Feb 2008
    Denton, TX
    5,061
    You probably just need filter time and patience. You're doing the right thing. Keep in mind that when you backwash, you are losing stabilizer (CYA) when you do it. This can make it tougher to maintain your FC in an algae battle. I would wait to backwash only when your filter pressure is at least 25% higher than it would normally when clean.
    Casey's Avatar
    SW PA
    10,446
    It also takes time for your filter to *filter out* all the particles in the water from the dead algae.
    POP = Pool Owner Patience!
    Apr 2013
    Arkansas
    5
    Thanks all! Appreciate the great advice!
    Oct 2007
    Cedar Hill, TN
    252
    Quote Originally Posted by finine
    Advice?
    Are you sure that the level neverwent below shock value at any time? If it did, that means you are starting from scratch at that point. The algae would just come back during that time.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Apr 2013
    Arkansas
    5
    Quote Originally Posted by heikejohn
    Advice?
    In the past 9 days it has not. That's when our test kit arrived.
    30,421
    You'll get there. Keep that pump and filter going 24/7 and brush when you can. Take a good swig of that POP Casey mentions.....we all have to do that from time to time, especially when clearing a pool.
    Apr 2013
    Arkansas
    5
    Appreciate all your experience and advice, we will keep at it. Never been a big drinker pop will sit on the table. Hahaha
    Apr 2012
    SW Ohio
    456
    you can add some d.e to the sand filter to filter out those fine particals and speed up the process, take some d.e and put it in a bucket and mix it with water and slowly pour it into the skimmer until the pressure rises 1 psi, but you have to re-add the d.e after every backwash and rinse....keep up the good work .....Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
