Thread: Anthony DE Filter manifold...Alternatives?
    Jul 2011
    Northern NJ
    92
    Hi all:
    I'm currently digging up all the gravel and dirt to expose the pipes leading to and from my pool equipment. I need to move all of it about 10 feet or so and I'd like to refresh, replace, rebuild or upgrade while I'm going through the trouble. I'm also removing all copper piping, connectors and (I'm guessing) brass gate valves. Thankfully the copper is only above ground, so matching everything up below ground level in PVC and finishing will be relatively easy.
    One of the pieces of equipment I'm not sure about is the filter manifold. This one does work but I was hoping to perhaps update to a modern style....and hopefully one that will line up to the existing filter inlet/outlet.
    Any suggestions are greatly appreciated.
    (Attached is a pic of the existing manifold)
    Anthony Pool, 35k gal plaster, DE (1.5hp Ultraflow), Rainbow 320, Dolphin Diagnostic 2001 (Advantage) & Polaris, Retrofitted Anthony mod #20 120v Niche light with Pentair 5G & adapter ring, 70's build / recoped and plastered 1.5 years ago
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Anthony DE Filter manifold...Alternatives?
    That's just a "slide bachwash valve." You have two positions: Filter and backwash. I'd look into a multiport valve. You then have the options of recirculate and waste, which lets you drain the pool easily, or bypass the filter if you're just interested in circulating the water for some reason.
    Jul 2011
    Northern NJ
    92
    Thanks Richard. Would you happen to know if a multi-port valve will fit up to the in/out ports on the filter?
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by rickmnj
    Not a clue. But if you get one that uses standard PVC, who cares? Plumb it where it fits best, or is most convenient.
    Jul 2011
    Northern NJ
    92
    Yup, that's what it's looking like. None seem to retrofit to the Anthony configuration. Thanks again!
