Results 1 to 8 of 8
Thread: pool uncovered, pump seized , chlorinate ?
    lindaspoolboy's Avatar
    north NJ
    23
    the pool was partially opened on friday; but when they went to start the pump it seized.
    it will hopefully be replaced tuesday.
    should i be putting liquid chlorine into the pool ?
    or just let it go until the pump is installed and then shock it ?
    (i'm in north jersey: forecast is 40s-60s/low 70s)
    thanks
    - lindaspoolboy
    29,000 gallon vinyl IG, Hayward 1.5hp Pump, DE Filter.
    30,404
    Re: pool uncovered, pump seized , chlorinate ?
    If your water temp is close to 60, I would get some chlorine in the pool. Stir it around with a boat paddle or board. The little bit of Clorox it takes is WELL worth it if it prevents algae from forming.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Row, row, row your pool!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    A Wall Whale can move a whole lot of water really fast, in case you're in the market for a new brush head this season anyway. Two or three passes would get the bleach completely dispersed.
    north NJ
    23
    thanks for the replies everyone. i'm out to paddle in some chlorine !
    Apr 2013
    Yorktown, VA
    35
    Mine was seized as well when I first tried to start it. I tapped the side of the motor at each end (where the motor bearings are) a few times to try to job the bearings loose. If yours was like mine, a small seal leak last year probably got into the bearings. I was able to get the motor running, but it is obviously not going to last long from the sound of it. I'm awaiting arrival of a new 2-speed motor now. At least I am able to circulate added chemicals and keep the water from stratifying (warm water layer near the surface that algae love) with the old motor in the mean time.
    If "percussive maintenance" doesn't let it start, the end of the motor shaft should have either a hex or a screw driver slot that you can use a tool to try to unfreeze it.
    33,000 gallon, IG vinyl, Hayward Super Pump, 1.5 Hp single speed, sand filter, salt system, built 2002
    Mine was seized at the beginning of last year as well. I took the motor off and used vice grips on the lower portion of the shaft and got it to spin manually. Once it was freed, I lubed it with a little WD-40 and it lasted for almost a full month before finally giving out for good.
    FYI, when the pump motor finally went, I went a week without filtering and didn't add chlorine in the middle of July. I had zero algae when the new pump motor finally arrived. When I got everything running I shocked the pool to be safe, but there were no signs of algae after even a week.
    Kevin
    30,000 gallon vinyl pool
    Hayward DE Filter
    Hayward Super Pump
    AO Smith 1 1/2 HP Pump (27GPM)
    Polaris 380 Pool Cleaner
    Check out the app I created to control my pool equipment from my smartphone:
    i-created-an-app-to-control-pool-equipment-with-smartphone-t61606-20.html
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Quote Originally Posted by kodiak1120
    Kevin
    I still would not recommend going without chlorine.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
