Thread: Jandy Replacement Cell
    Swampfox's Avatar
    Apr 2013
    Birmingham, Alabama
    2
    Hi, new here and need some advice. I have a 3 year old Jandy Aquapure 1400 installed on a ~22,000 gallon in ground Gunite pool (builder went broke - I am on my own now). The fault code indicated to clean the cell. I cleaned it but one of the DC connection pins pushed into the housing (water leaks through the pin sockets). I took it apart and the o-rings are "loose" and don't keep the pins in place. I cleaned the plates per instructions put sealer on the o-rings and reassembled (non-conductive sealer applied sparingly). Now I get a fault code to replace cell.
    From what I have read, I should replace the cell and be done with it. The question is OEM Jandy or CompuPool? Or take a chance on having it rebuilt? Advise appreciated! Thank you!
    16'x36' shot-crete, vanishing edge pool; SWG Jandy Aquapure 1400 w/iLink phone ap; Paramount in-floor cleaning; Hayward 1-1/2 hp & 3/4 hp Super-Pumps.
    22,545
    Re: Jandy Replacement Cell
    While you can't go wrong with the mfg cell there has been some good reports on the compupool cells.
    Swampfox's Avatar
    Apr 2013
    Birmingham, Alabama
    2
    Thanks Dave. I guess it comes down to cost per year and warranty. The Compupool SWG is about $200 less and comes with a cord and a 2 year warranty. I wish there was a way to rebuild the "guts" of the unit and not have to pay for another housing but I guess that's not an option....
