Thread: What is a good depth for the shallow zone of a pool
    We are going to build a inground L shaped pool and was wondering what depth is a good depth for the shallow leg. The dimensions of the pool will be 45 x 20 and 36 x 18. The 36 x 18 leg will be the shallow area. We just received the engineering drawing and they have it at 3 1/2 feet at one end tapering to 4 1/2 at the other end. I had the impression that it would be 3 1/2 all the way . We would like this area for playing volleyball, basketball and catch etc. 4 1/2 seems a little deep. Is tapering this area standard? Is 3 1/2 feet adequate or to shallow? What do you think? We are just an average size family with 3 kids ages 12 to 18. Your insights are always welcome.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    Re: What is a good depth for the shallow zone of a pool
    Our play pool is 3 1/2 on each end and 4 1/2 in the middle. This creates good flow to a main drain, yet makes it easy to play games from either end.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    30,403
    "Standard" is what you want. It seems pretty obvious you want it to be 3.5 throughout so why not make it that way? Is someone objecting?
    Elwood58,
    If the tapering is for drainage I like your layout better, 3 1/2 at each side and taper to the middle to 4 1/2. Thats a better design then the way we have it now. Food for thought. Looking for that happy medium between to shallow and to deep, if it exists!!
    Thanks for your kind response.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    What type of pool finish? Gunite? Liner?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    gunite
