Thread: Pool looks like a green swamp
    I wonder what I am doing wrong. My pool looks like a green swamp when I open it, and it is filled with frog eggs. It is covered all winter long but this has happened both years.
    I created a thread for you. Please don't threadjack. It is hard to help when we have to sort out who has what going on. Thanks! 257WbyMag - Forum Moderator
    Doughboy 18x38 AGP buried 2' deep. 18,400 gal. Hayward Power Flo Matrix. Hayward Pro Series High Rate Sand Filter. TF-100 test kit.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Pool looks like a green swamp
    How do you cover it in the winter? Most covers I have seen leave pretty big spaces between the holes that you string the tension wire through which can be an area that critters enter your pool from.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    30,432
    If you have a mesh cover, you are going to have some algae. Folks with a solid cover open to cleaner pools but it can be fixed either way.
    It is a tension wire type cover. Is there another kind for above ground pools?
    It is also solid, not mesh, and I would call this more than "some algae."
    Feb 2008
    Denton, TX
    5,061
    Scoop out what you can and then shock your pool. Here's a helpful link...pool-school/shocking_your_pool
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Depending on where you are located, you may be closing early and opening a tad late. Water should still be relatively clear if you close after water temp drops below 60deg and open before the water temp is above 60 deg.
