Results 1 to 14 of 14
Thread: Some real numbers, so next steps should be....
    Taylor kit arrived and I ran a few tests, but super super tired, so may need to run more tomorrow.
    TEST RESULTS
    cya==70
    FC==9
    CC==0
    PH==8.0
    AD==3.5
    POOL CONDITIONS
    some algae growing
    moderately clear [ very hard to tell as plaster is moddled ocean water color]
    temp is about 76
    highs next 8 days in low 90's
    filter needs more spraying
    debris baskets are clean
    about 36k gallons [18x38x8]
    Need to addressed
    1- ph, again
    2- algae
    3- cya
    4- filter media
    Don't know if I need more tests, if you think any would be helpful, please advise.
    Plan:
    1. rinse out filter media, [no time to order new media]
    2. drop ph. Think I need to add 1 gallon acid
    3. wait 3 hrs with pump running
    4. add 12 gal liq chlorine [but pick up another 12 for followup and more plastic gloves]
    I think this will raise FC from 9 to 30
    Questions:
    1 is your preference disposable or rinseable gloves
    2. what do you do with used sample/regeant mix?
    3. does the CH number seem about right?
    4. what else should I look out for?
    5. would you leave the cya level alone, or plan to drain some of the pool to lower the level?
    Thank you for reading and any comments
    36K gal, gunite w/ plaster,[18W x 38L x 8 deep end] 300SF cartridge, 80-100 GPM filter, Sta-rite S7M120 and Polaris 9300 electric robot. Rooftop 6 panel Solar heater, Sacramento Valley, Climate Zone 8
    Feb 2008
    Denton, TX
    5,061
    Re: Some real numbers, so next steps should be....
    What are the gloves for? Just curious.
    pH does need to come down. Since you have algae, you need to shock your pool. With your CYA, this means raising your FC to 28 and holding it until you have no more algae,the water is clear, you have 0.5 CC or less, and your FC holds to within no more than a loss of 1 overnight. You could do a little draining and refilling to get that CYA down. Up to you though.
    I don't see a CH in your results.
    Vette's Avatar
    Jul 2012
    Ohio
    404
    If you have algae, shock before you play with the rest.
    -Sent from Galaxy Note 2
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    30,402
    Almost right. Lower your pH before you begin to shock. Since you imply your pH has risen before (don't be stingy with info), lower your pH down to around 7.2 - 7.4. Use the pool calculator to tell you how much acid.
    Now, start the shock process. Follow the article in Pool School precisely.....it's not a one time dose of chlorine.
    1. I don't use gloves
    2. Toss them out....quite harmless
    3. What does "AD" mean in your test results? there is no CH.
    4. Not shocking the pool correctly....read the article
    5. I'd leave it alone....it's where you want to be for an SWG.
    1. gloves are for safety with liquid chlorine and muriac acid in case gets on skin, vs 20 minute skin wash
    2. great, good to know. all kinds of warnings on unmixed chemicals
    3. AD is acid demand drops for ph test. I was dropping too fast and was clear at 3 drops even though I used 4 drops.
    5. it's a fresh water pool.
    the ph seems to be rising from the chlorine, or something. have to remove some leaves weekly and sometimes daily. polaris gets run on long cycle at least once a week. ch was my abbrev for chlorine. fc is free chlorine, cc is combined chlorine.I also lose water and had to had hose running about 30 min to raise the water level. Haven't tested ph of city water. now that warm weather is here, 90's for next 8 days, it'll probably be 60-90 min of water add a week.
    30,402
    Sorry, I assumed SWG. Then CYA is a bit high (should be 50ppm) but it sounds like you are adding quite a bit of water as routine maintenance so it may reduce on it's own.
    Very interesting experiment.
    Treatments since last update
    1.5 gal muriac acid
    12 gallons of 10% chlorine
    boy did the pool smell of chlorine
    started the polaris
    left the pool pump on all night
    This mornings sample
    STRIPS
    FC ==10
    Alkaline 100
    PH 7.4
    TAYLOR
    FC == 000 <------------#####
    CC == 000 <------------#####
    Added 6 gallons chlorine
    Tonight
    STRIPS {aquacheck 5}
    FC == 10
    others the same
    TAYLOR
    {NOTE: previous FC measures are 5x too high}
    FC == 22
    Total Alka == 125
    Calc Carb/hardness == 750
    PH == 7.8
    CYA == 55 {more careful testing}
    Observations:
    1- water is now clear. But, alas, even with clear clear water the pool doesn't look great. I think it's because the
    moddled sea foam plaster looks ugly, but I imagine a plaster job would be 4k plus 30 days without the pool, but
    that is just a stab in the air with no supporting facts.
    2- algae is gone
    3- ph has risen again
    Interested in theories for:
    1. difference in FC between strips & Taylor
    2. why Taylor showed 0 chlorine this morning. My best guess is the 90 min run of the polaris
    stirred up the water so much, the chlorine evaporated.
    Not planning on swimming for a few days, so probably will leave the FC high but need to get some acid to lower the ph.
    Any suggestions for next steps and why the difference between the test results?
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by Notri4MeBikeSwim
    Test strips are a half step below worthless.
    It is possible that there is still low level algae in your pool consuming your chlorine and you just can't see it. Only an OCLT will confirm this.
    Apr 2012
    SW Ohio
    456
    I would not trust your ph test, when Chlorine is above 10 ppm it throws of the pH test.
    Are you following the shock process ....add chlorine.....wait a hour and test and repeat....etc ? Also a good daily brushing is in order....lol
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    haven't tested today, just ran polaris two cycles. The polaris is an electric pool cleaner with two rollers with about a dozen wavy semi hard plastic surfaces. It gathers a lot of debris and seems to break up the algae previously. Excellent point about algae "not seen". I'll get tests tomorrow. Water still appears clear and pump was running only about 8 hrs today, vs normal 5-6. One turn is about 5 hours of pump time. Very windy today so fair amount of stuff blown into pool. Most is out, but some will surely be there tomorrow.
    I don't know the OCLT abbreviation.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Overnight chlorine loss test.
    Chlorine is consumed by sunlight and by organics. Eliminate sunlight and if you don't lose any, you don't have organics aka algae. Simple, huh? You'll need the FAS-DPD test for it. Take a reading after the sun stops shining on the pool then recheck it in the morning before the sun hits it again. There's a longer explanation in Pool School.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Over night chlorine loss test
    Jeff
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Whoops Richard beat me.
    Jeff
    Must have worked, even though sloppy method. Tested today and FC is still 7 and CC is 0. You're right don't need phosphate reducers. Water looks nice and clear, thank you all for your help.
