Results 1 to 9 of 9
Thread: Dawn dusk sensor ??
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Dawn dusk sensor ??
    I want a dawn to dusk sensor to turn my pool lights on and off .
    I currently have 2 light switches Pool, Spa ....
    I have the color splash 3g led lights and still need a switch to change the colors and such.
    Has anybody seen a standard light switch will a sensor built in !!!
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Re: Dawn dusk sensor ??
    Do you mean an outlet that is activated by the sensor ?
    http://www.amazon.com/2001-Outdoor-24-H ... usk+sensor
    So many variations of these.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Never seen one in a switch. I have seen ones that screw in to a floodlight socket, or you can hardwire one like thisin between the switch and the load.
    22,550
    You could use a couple of home automation devices to do it and retain the switch. I use a lot of Insteon and could do it with a micro relay switch and a motion sensor that will act as a dusk to dark sensor. You don't need any more automation to do that.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I guess if i put the sensorvbetween the switch and the load and left the switches on then it would work ..
    Thanks...
    Sean Hannon
    22,550
    Yes that would work.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Got it done .. Found a sensor at the depot .. it works !!!!
    And the two switches are still operational to change the color of the lights .
    Note: all the sensors are 1/2 inch , my electrical box is 3/4 inch..
    Found 2 brass adapters in the plumbing dept. that worked .
    Gonna be cool when the lights automaticly come on !!!!
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Pic
    Sean Hannon
    22,550
