Results 1 to 9 of 9
Thread: Sodium Chloride vs Calcium Chloride to raise hardness
    Apr 2013
    New Hampshire
    9
    Hi, I inadvertently added sodium chloride ( salt) to my pool ( 80lbs worth) thinking that it was calcium chloride. I noticed that it did not raise the hardness of the water and realized that I put in the wrong product.
    Question: I plan on adding the correct product ( Calcium Chloride) tomorrow to raise the hardness. Will there be an issue with the salt already in the pool? The pool is 45,000 gallon gunite. Just opening for season . I use chlorine also. Thanks, and I'm glad that I found this forum. Cheers, Tom.
    38,370
    Re: Sodium Chloride vs Calcium Chloride to raise hardness
    Welcome to TFP!!!
    What kind of salt did you add? For a water softener? As long as there were not additives in it, all it will do is raise your salt level by a little over 200ppm ... pools that use salt water chlorine generators have salt levels around 3500ppm. So, no worries.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    None - some people add salt to improve the feel of the water
    You can use the Pool Calculator to see how high your salt level may be now. Use the "Effects of Adding Chemicals" section, though there may already be some salt in the water to start with.
    We're glad you found it too!
    (Jbizzle beat me to it and made a very good point!)
    Cheers!
    Apr 2013
    New Hampshire
    9
    Thanks for your quick response. Yes, it said Morton pool salt on the label and stated that it had no additives and was pure. It also said something about use in water softeners too. Glad to hear that there won't be an issue. Won't make this mistake again. Looking back, the price for these bags were about one fifth of that of calcium chloride...now I know why.
    38,370
    We actually also recommend using just solar salt as it is half the price of the pool salt ... same stuff, just not ground up as much.
    Apr 2013
    New Hampshire
    9
    Thanks for the advice , much appreciated. The big test now is going to see if my Hayward Super II 2hp pump fires up after ten New Hampshire winters. Ran well when we shut her down in late September. Who knows, I may be asking advice on what brand pumps you recommend, but I hope not for now. Fingers Crossed.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Fretster
    Adding 80 lbs of calcium chloride will move your CH level up 192 ppm, which is a big step and may not be warranted. If you want, post your TA, ph, CH, cya, salt and borate levels...if you do not know what I am asking for post back.
    Apr 2013
    New Hampshire
    9
    Typically I add about thirty to thirty five pounds of Calcium Chloride on start up day. This usually brings me into the acceptable range for hardness.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What is your CH now?
