Thread: Clogged up bubbler valve
    I have a polynesian pool with a set of fiberglass steps. On the wall of the steps is a valve/nozzle with a water jet. Also it puts bubbles into the pool. There is a small PVC pipe/valve in the concrete right above the valve/nozzle that you can screw to control the air flow.
    This valve/nozzle is clogged. I think there is a little twig on the inside.
    My question is how do I clean out the clog? I was thinking I need to unscrew the nozzle and it would pop out. I can't figure out how to take it apart. Does anyone know what this thing is called and is there a diagram somewhere I can refer to? My fear is if I try to force it the wrong way it would break. Thanks for any suggestions you might have.
    Re: Clogged up bubbler valve
    Here is a picture of the nozzle close up. The nozzle will tighten or loosen. There is a ring around the nozzle with 4 feet that stick out. Looks like there would be some kind of special tool like one of those tools that you can take out a shower drain with. I'm thinking I can unscrew the nozzle as a piece and clean out the debris behind it. Any ideas?
    The ring says SP 1434 D with the notches
