Results 1 to 15 of 15
Thread: Need some advice on startup
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Starting over with fresh water after light housing replacement. And crack repair.
    Water in pool is straight out of hose
    .5 fc
    2.5 cc
    3.0 tc
    80 ta
    0 cya
    160 salt
    8.2 ph
    I have added nothing yet.
    30.000 gallons
    Pool calculater say to add
    218 oz 6% bleach
    42 oz murectic acid.
    Should i just add them both ??
    Or add bleach tonight and acid tomorrow after testing again ??
    Thanks !!!
    BTW i installed the color splash 3 g bulbs in the pool and spa abd they are cool !!!
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    38,520
    Re: Need some advice on startup
    You need to be adding CYA and getting the pH down and adding chlorine.
    Your FC is going to disappear very fast due to the sun until you get the CYA in the pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Just to add to what jbliz said,
    I would start with lowering ph first. The test reads 8.2 for ph at or above that level...so you could be above.
    Test again after about 1 hour of circulation, then adjust again, and repeat till ph is in range (7.5-7.8)
    Once you have that in range, double check you TA to make sure you are not below 60 ppm.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Others may chime in, but I would get the Muriatic in there and get the pH down. Let it mix for 30 minutes and then add Bleach. I would distribute both around the perimeter. There is a pretty good chance that your pH is higher than 8.2 as that is where the scale maxes out, so keep an eye on it.
    It will then be time to get some CYA in there. Follow the pool calculator, but hold back on the full dose until you get measurable results, which could be 3-5 days. You do not want to overshoot your target.
    Congrats on getting the repairs done.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I will be using the instant liquid conditioner from pool supply world.
    It say it doesent effect PH that much ??
    I dont know first time to use it ...
    Sean Hannon
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    yes, cya does not have much effect on ph
    Did you get your ph down yet?
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Some pics
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    No still wating for water to reach skimmer ...
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Cya and bleach
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    The pic of the light shows the alladen adapter ring and the new pentair light with color splash 3G led bulb
    The old light was a Anthony model 30 new in 1983
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    When i turn on the light it looks like close encounters of the 3rd kind in my backyard !!!!
    Sean Hannon
    38,520
    You find the disco mode yet?
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Yea staying alive ......
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Disco pics after dark!!!
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Night pic
    Sean Hannon
